Ludus Mazda Rx7 Fd3s... Jdm power
    [YOUTUBE]PArQgneeCe4&feature=plcp[/YOUTUBE]
    Poi non rompo pi? le balle a Ludo
      ludo ti sei messo a studiare?
        Avevo detto che non rompevo pi? poi mi vedo questo...
        La Badbul ? rinata in NZ
        THE BADBUL RELOADED - Speedhunters
        BADBUL MAZDA RX-8
        ENGINE: Mazda 20B 3-rotor; Kiwi-RE Monster Bridgeport; lightened/balanced rotors; cross-drilled eccentric shaft; Kiwi-RE apex seals; modified stationary gears; HKS T51R turbocharger; custom exhaust manifold; Turbosmart Mad Mike Signature Edition 60mm Power-Gate 60 external wastegate; Redline Performance GT-R intercooler; Turbosmart blow-off valve; K&N air filter, custom 3.5″ stainless steel exhaust system; custom fuel cell; 2x Bosch Motorsport 044 fuel pumps; Bosch Motorsport lift pump; high-flow fuel lines; Turbosmart adjustable fuel pressure regulator; custom fuel rails; high-flow injectors; Gilmer belt drives, custom catch tank and overflow bottle; Redline Performance alloy radiator; 2x Setrab oil coolers; intercooler and radiator water sprayers
        ENGINE MANAGEMENT / ELECTRONICS: Haltech Sport 2000 ECU; custom loom
        DRIVELINE: HKS 6-speed sequential gearbox; HKS Pro 2 twin-plate clutch; HKS flywheel; ASD/Winters quick-change rear end; ASD limited slip differential; custom Driveshaft Shop axles
        SUSPENSION / CHASSIS: Custom built Tein Super Drift/Mono Flex suspension; Tein EDFC, FD3S RX-7 steering rack; Megan Racing steering arms; URAS tie-rods; Megan Racing tie-rod ends, MM/BSL Racing steering knuckles
        WHEELS / TIRES: Front: 18?10″ Nessen Forged 8-spoke, Nitto NT05 225/40R18 tires; Rear: 18?11″ Nessen Forged 10-spoke, Nitto NT05 (dry) and Nitto INVO (wet) 265/35R18 tires
        CABIN: Six-point weld-in rollcage; Racetech RT9009 carbon/Kevlar seats; Racetech 3″ harness belts; RacePak digital dash; BSL Racing hydraulic e-braker lever, Lifeline fire extinguisher system; D2 Racing air jacks; custom switch board
        BODY: Street Pro/Lokey custom wide body kit; BN Sport vented hood; Seibon carbon fiber doors; Seibon carbon fiber trunk lid; Sard GT wing; BSL Racing laser-cut wing mounts; V-LED patrol lights; custom CRE8GRAFX livery
          prove di makeup...fresco fresco di corriere...l'estrattore posteriore ... le dona un tocco Sexy..... xD
            che brutto lo scarico per?
              lo s? benjo....ma la prolunga a becco ? obbligatoira senn? prende fuoco il paraurti posteriore... gi? con quella la vernice ? cotta
                lo so ma fa molto punto GT rumena
                  Vedessi quelle in D1GP che scarico a becco hanno ultimamente!
                    un sacco di scarichi da competizione ha l'uscita a becco ormai..
                    a me sulle JDM piace... se lo fai un po' pi? grosso e in titanio ? il TOP!
                      cribbio ? gi? da 80mm xD.. pi? grosso non si pu?
                        mamma mia che spettacolo!
                        ma una rx7 si puo fare asi???
                          si certo che si f? Asi... anzi ? di notevolissimo interesse storico inquanto l'unica auto wankel turbo
                            sembra un due tempi
                            il rotore ? simile ad un 2 tempi in effetti
                              complimenti, bellissimo mostro, posso chiederti quanto costa una roba del genere ?
                                questa l'ha da 120mm :gaen:
                                Auto usate: Mazda, RX-7, Single Turbo Efini AutoScout24 pagina di dettaglio
