Originally posted by SUPERALEX
View Post
si era partiti col nobile scopo di creare una categoria con costi accessibili
ci si è resi conto,che i piloti bmw, dovevano girare senza controlli, a causa dell'elettronica troppo stradale.
adesso ci si ritrova con i piloti bmw, che possono usare elettronica alpha racing...7k, che per alcuni aspetti è anche più sofisticata della motec della classe civ sbk
adesso uno potrebbe anche essere invogliato a usare un cbr, perchè l'elettronica hrc è molto avanzata.
dove si andrà a finire? che se la bmw migliora e arriva a livello di ducati, qualcuno inizierà a lamentarsi.
bisognava prendere spunto dal regolamento della superstock inglese
"in order to equalize the performance of motorcycles used in the MCRCB Superstock Championships a system of performance enhancements or restrictions (such as but not limited to authorised parts, minimum weight, air restrictor or Rev Limit) may be developed or applied according to their respective racing performances.
The minimum weight value is determined by the dry weight value (kg) 1100cc 4 cylinders 178kg 1000cc 4 cylinders 174kg 1200cc 2 cylinders 174kg
"The standard homologated ECU may be used. For the avoidance of doubt flashing the standard supplied ECU is NOT authorised. A manufacturer’s authorised “kit” ECU may be used with manufacturer authorised firmware. The rev limit must be as the standard homologated ECU and will be checked on the Dyno for compliance. Where a manufacturers “kit” ECU has a dash that is an integral part of the “kit” with no additional functions over the “dash” from the homologated model then it may be used, providing there is no alternative “kit” ECU from that manufacturer for that model and is within the MSVR price cap of £3,500 plus VAT for the complete kit. The manufacturer must provide MSVR with the means to check the dash. For models where a manufacturer’s kit ECU is not available, the promoter/organiser will in conjunction with the relevant manufacturer and an official technical partner, make available authorised firmware for use with the standard ECU. This will be the sole authorised firmware for that particular machine model. As detailed in 1.10.2 in the case of the Superstock class, motorcycles over 1000cc up to 1100cc must be equipped with the MCRCB/MSVR specified ECU and dash - see MCRCB authorised parts list. MCRCB/MSVR will impose functionality and performance controls at their exclusive discretion. This may include; disablement of rider aids, rev limit, throttle position control. Full details of the motorcycle model and the MCRCB/MSVR prescribed technical interventions will be published by Bulletin."
nessuno si lamenta, sono tutti competivi, e nessuno bara
