mi permetto di postare qua
sono andato a lavorare a casa di un signore...in garage,oltre a qualche macchina d'epoca,aveva anche questa moto
facendo un attimo di ricerca su GOOGLE ho trovato anche qualche dato ...
Production: 1957-1964
Units built: 1957:5000 1958:1189 1959:1854 1960:3067 1961:4460 1962:2401 1963:7500 1964:6000
Engine: 1 cylinder four-stroke, dry sump with external oil tank and MICRONIC paper oil filter
HP: 12.5 at 6500 rpm
Engine displacement: 174cc
Cylinder diameter: 62mm
Piston stroke: 58mm
Piston to cylinder wall clearance: 0.05 mm
Compression ratio: 7.5:1 max.7.9:1
Ignition timing: 5.5 mm or 32 deg. before Upper Dead Center (UDC) with mechanical spark advance device in full open position
Spark plugs: W 240 T1, gap: 0.6-0.7 mm
Valve clearance (cold engine, piston in UDC, both valves closed): Intake valve: 0.08 mm, Exhaust valve: 0.08 mm
Valvetrain: OHC, camshaft driven by ULTRAMAX rods, hairpin-style valve springs
Carburetor: BING 2/22/27 main jet:85, idle jet 35, needle jet 2.66, needle 2nd groove from top, idle screw 1.5 turns open
Transmission: 4 speed
Frame: solid NSU sheetmetal frame
Brakes: 140 mm drum brakes
Tire size: 3.25-18"
Weight: 124 kg
Length: 1997 mm
Maximum weight: 293 kg
Gas tank volume: 10.8 ltr
Oil tank volume:1.4 ltr, summer: SAE 20, winter: SAE10. Change every 2000 km. Let engine idle long enough to pump the oil up into the oil tank; THEN check the dipstick!!!!)
Fuel consumption: 3.2 to 3.5 ltr/100 km
Top speed: 110 km/h
General information: The Maxi has many features of the Supermax ("little sister of the Max"), although the design is actually an improved Superfox design.
sar? vecchia e fuori moda,ma ha il suo fascino
Piston stroke: 58mm
Tire size: 3.25-18"
Weight: 124 kg
Length: 1997 mm
Top speed: 110 km/h
