RODAGGIO: due interpretazioni...e una cosa in comune
    Handbooks, as in most things, play safe in telling you how to run in an engine, usually suggesting 1,000 miles (1,600km) or more. But for once this can do more harm than good. According to Peter Brett from the world leading Castrol Technology Centre in Pangbourne in south east England, 500 miles (800 km) is about right for a modern bike engine. ?Running in now is more about cleaning up the manufacturing and stabilising the surfaces, which means taking it a bit easy for the first 500 miles,? he says. ?Not too easy though! In practice, this just means riding normally. The worst thing you can do is load an engine at low revs, and avoid very high revs at first. Build up gradually and don?t suddenly give it full power as you pass the 500 mile mark after being gentle!?
    There?s very little a owner can do to find out if his engine is running in properly ? Castrol measures blow by, the gas escaping past the piston rings, but even this on many modern engines is minimal from new. You could always send off your pistons for a microscopic examination, but this isn?t very practical... And as mentioned, oil consumption will rarely be noticeably different, even if it halves as you run in.
    Try to keep your engine cool while it's running in
    But do keep an eye on the temperature gauge. A new engine runs hotter because of its higher friction, and if the needle starts to rise above normal, back off the throttle or if it?s hot because you?re in traffic, stop for a while to let it cool. Although liquid cooling and the electric fan will prevent real overheating, even so you?ll get higher than ideal localised temperatures which can interfere with running in.
    Don?t mollycoddle your new engine with expensive oils either. Running in oils are rare and completely unnecessary on a modern engine, but here?s a shock, don?t splash out either on a costly fully synthetic oil until your engine?s covered at least 5,000 miles (8,000km). This comes from the highest authority, Castrol, who would love you to buy the company?s expensive synthetic oils...
    This is why the Castrol boys know what they're talking about
    Peter Brett says that they?ve discovered synthetic oils actually interfere with running in, for reasons which go beyond their low friction properties - there also seems to be a chemical process happening which hinders it. ?Although you can treat an engine as fully run in after 500 miles, surface stabilisation continues for at least the first 5,000 miles of an engine?s life,? he says. ?Synthetic oils actively prevent this from happening, and not simply by holding friction surfaces apart, although we still don?t know exactly why and how this happens. But there?s no doubt they inhibit the process itself. So the consequence of using a synthetic too early is your engine will never run in properly. I would even suggest waiting until 10,000 miles (16,000km) before using it in most engines subjected to normal use. Until then, you?re best to use an inexpensive but branded mineral oil.?
    So, save money by using a cheaper oil when your engine is new, it will run in properly and you will improve its longevity, power output and oil consumption. Can?t be bad, and that comes from people whose interest is in selling you expensive synthetics.
    It?s worth noting that when you do reach the mileage where a synthetic will start to be of benefit, only use a fully synthetic if it?s specifically designed for motorcycles with wet clutches (unless your bike has a dry clutch anyway, eg Ducati, BMW, Guzzi) or you?ll suffer clutch slip. Otherwise go for a semi-synthetic, but even then check it?s suited to wet clutch systems.
    * Coat of iron
    Dull grey coating on the pistons is a ferrous solid lubricant, and it won't look like this for long
    The irony with modern engines being so resistant to early abuse is that many, if they?re stripped down after a few miles, look like they?ve run 50,000 miles (80,000km) on old sump oil. More specifically, the pistons on many bikes can look badly scratched and scored even after a gentle first 500 miles. Don?t worry mister, they all do that...
    The reason is a relatively new idea of adding a ferrous coating to pistons (ferrous being iron, but it doesn?t sound as trick...) partly because it acts as a solid lubricant, reducing friction. In addition, it separates the rest of the piston from the bore, which is very helpful because when similar materials rub against each other they are much more likely to pick up and scuff than two different materials. Pistons are made of aluminium which also happens to be the base matrix material for bore linings such as Nikasil, so separating the two with a thin layer of iron reduces the chances of pieces of aluminium from one being picked up by the other.
    The iron coating though is soft, and in the early stages of an engine?s life, small pieces of very hard silicon carbide are knocked off the bore walls. These then leave score marks on the piston?s surface, giving the impression it?s already wearing badly. It?s not, and the scratches have no effect on performance, oil consumption or anything else.
    __________________________________________________ ______________
    I wrote "Break-In Secrets" after successfully applying this method
    to approximately 300 new engines, all without any problems whatsoever.
    Links to this article now appear on hundreds of motorsports discussion forums from all over the world. The reason is that over time, large numbers of people have done a direct comparison between my method and the owner's manual method, and the news of their success is spreading rapidly.
    The results are always the same... a dramatic increase in power at all RPMs. In addition, many professional mechanics have disassembled engines that have used this method, to find that the condition of the engine is much better than when the owner's manual break-in method has been used.
    The thing that makes this page so controversial is that there have been many other break-in articles
    written in the past which will contradict what has been written here.
    Several factors make the older information on break-in obsolete.
    The biggest factor is that engine manufacturers now use a much finer honing pattern in the cylinders than they once did. This in turn changes the break-in requirements, because as you're about to learn, the window of opportunity for achieving an exceptional ring seal is much smaller with
    newer engines than it was with the older "rough honed" engines.
    In addition, there is a lot less heat build up in the cylinders from ring friction
    due to the finer honing pattern used in modern engines.
    The other factors that have changed are the vastly improved metal casting and machining
    technologies which are now used. This means that the "wearing in" of the new parts
    involves significantly less friction and actual wear than it did in the distant past.
    With that in mind ...
    Welcome to one of the most controversial motorsports pages on the internet !!
    How To Break In Your Engine For
    More Power & Less Wear !
    One of the most critical parts of the engine building process is the break in !!
    No matter how well an engine is assembled, it's final power output is all up to you !!
    Although the examples shown here are motorcycle engines,
    these principles apply to all 4 stroke engines:
    Street or Race Motorcycles, Cars, Snowmobiles, Airplanes & yes ...
    even Lawn Mowers !!
    ( regardless of brand, cooling type, or number of cylinders. )
    These same break in techniques apply to both steel cylinders and Nikasil, as well as the ceramic
    composite cylinders that Yamaha uses in it's motorcycles and snowmobiles.
    What's The Best Way To Break-In A New Engine ??
    The Short Answer: Run it Hard !
    Why ??
    Nowadays, the piston ring seal is really what the break in process is all about. Contrary to popular belief, piston rings don't seal the combustion pressure by spring tension. Ring tension is necessary only to "scrape" the oil to prevent it from entering the combustion chamber.
    If you think about it, the ring exerts maybe 5-10 lbs of spring tension against the cylinder wall ...
    How can such a small amount of spring tension seal against thousands of
    PSI (Pounds Per Square Inch) of combustion pressure ??
    Of course it can't.
    How Do Rings Seal Against Tremendous Combustion Pressure ??
    From the actual gas pressure itself !! It passes over the top of the ring, and gets behind it to force it outward against the cylinder wall. The problem is that new rings are far from perfect and they must be worn in quite a bit in order to completely seal all the way around the bore. If the gas pressure is strong enough during the engine's first miles of operation (open that throttle !!!), then the entire ring will wear into
    the cylinder surface, to seal the combustion pressure as well as possible.
    The Problem With "Easy Break In" ...
    The honed crosshatch pattern in the cylinder bore acts like a file to allow the rings to wear. The rings quickly wear down the "peaks" of this roughness, regardless of how hard the engine is run.
    There's a very small window of opportunity to get the rings to seal really well ... the first 20 miles !!
    If the rings aren't forced against the walls soon enough, they'll use up the roughness before they fully seat. Once that happens there is no solution but to re hone the cylinders, install new rings and start over again.
    Fortunately, most new sportbike owners can't resist the urge to "open it up" once or twice,
    which is why more engines don't have this problem !!
    An additional factor that you may not have realized, is that the person at the dealership who set up your bike probably blasted your brand new bike pretty hard on the "test run". So, without realizing it, that adrenaline crazed set - up mechanic actually did you a huge favor !!
    Here's How To Do It:
    There are 3 ways you can break in an engine:
    1) on a dyno
    2) on the street, or off road (Motocross or Snowmobile.)
    3) on the racetrack
    On a Dyno:
    Warm the engine up
    completely !!
    Then, using 4th gear:
    Do Three 1/2 Throttle dyno runs from
    40% - 60% of your engine's max rpm
    Let it Cool Down For About 15 Minutes
    Do Three 3/4 Throttle dyno runs from
    40% - 80% of your engine's max rpm
    Do Three Full Throttle dyno runs from
    30% - 100% of your engine's max rpm
    Go For It !!
    Frequently asked Question:
    What's a dyno ??
    A dyno is a machine in which the bike is strapped on and power is measured.
    It can also be used to break in an engine.
    NOTE: If you use a dyno with a brake, it's critical during break - in that you allow the engine to decelerate fully on it's own. (Don't use the dyno brake.) The engine vacuum created during closed throttle deceleration sucks the excess oil and metal off the cylinder walls.
    The point of this is to remove the very small (micro) particles of ring and cylinder material which are part of the normal wear during this process. During deceleration, the particles suspended in the oil blow out the exhaust, rather than accumulating in the ring grooves between
    the piston and rings. This keeps the rings from wearing too much.
    You'll notice that at first the engine "smokes" on decel, this is normal, as the rings haven't sealed yet. When you're doing it right, you'll notice that the smoke goes away after about 7-8 runs.
    Important Note:
    Many readers have e-mailed to ask about the cool down, and if it
    means "heat cycling" the engine.
    No, the above "cool down" instructions only apply if you are using a dyno machine to break in your engine. The reason for cool down on a dyno has nothing to do with
    "Heat Cycles" !!!
    Cool Down on a dyno is important since the cooling fans used at most dyno facilities are too small to equal the amount of air coming into the radiator at actual riding speeds. On a dyno, the water temperature will become high enough to cause it to boil out of the radiator after
    about 4 dyno runs. This will happen to a brand new engine just as it will
    happen to a very old engine.
    (Always allow the engine to cool down after 3 runs whenever you use a dyno.)
    If you're breaking your engine in on the street or racetrack, the high speed incoming air will keep the engine temperature in the normal range.
    (In other words, you don't have to stop by the side of the road to let your bike cool down.)
    What about "heat cycling" the engine ??
    There is no need to "heat cycle" a new engine. The term "heat cycle" comes from the idea that the new engine components are being "heat treated" as the engine is run. Heat treating the metal parts is a very different process, and it's already done at the factory before the engines are assembled. The temperatures required for heat treating are much higher than an engine will ever reach during operation.
    The idea of breaking the engine in using "heat cycles" is a myth that came from the misunderstanding of the concept of "heat treating".
    On the Street:
    Warm the engine up completely:
    Because of the wind resistance, you don't need to use higher gears like you would on a dyno machine. The main thing is to load the engine by opening the throttle hard in 2nd, 3rd and 4th gear.
    Realistically, you won't be able to do full throttle runs even in 2nd gear on most bikes without exceeding 65 mph / 104 kph. The best method is to alternate between short bursts of hard acceleration and deceleration. You don't have to go over 65 mph / 104 kph to properly load the rings. Also, make sure that you're not being followed by another bike or car when you decelerate, most drivers won't expect that you'll suddenly slow down, and we don't want
    anyone to get hit from behind !!
    The biggest problem with breaking your engine in on the street (besides police) is if you ride the bike on the freeway (too little throttle = not enough pressure on the rings) or if you get stuck in slow city traffic. For the first 200 miles or so, get out into the country where you can vary the speed more
    and run it through the gears !
    Be Safe On The Street !
    Watch your speed ! When you're not used to the handling of a new vehicle, you should accelerate only on the straightaways, then slow down extra early for the turns. Remember that both hard acceleration and hard engine braking (deceleration) are equally important during the break in process.
    On the Racetrack:
    Do one easy lap to warm up your tires. Pit, turn off the bike & check for leaks or
    any safety problems. Take a normal 15 minute practice session
    and check the water temperature occasionally. The racetrack is the perfect environment to break in an engine !! The combination of acceleration and deceleration is just the ticket for sealing the rings.
    Go For It !!
    Yeah - But ...
    the owner's manual says to break it in easy ...
    Notice that this technique isn't "beating" on the engine, but rather taking a purposeful, methodical approach to sealing the rings. The logic to this method is sound. However, some will have a hard time with this approach, since it seems to "go against the grain".
    The argument for an easy break-in is usually: "that's what the manual says" ....
    Or more specifically: "there are tight parts in the engine and you might do damage or even seize it if you run it hard."
    Consider this:
    Due to the vastly improved metal casting and machining technologies which are now used, tight parts in new engines are not normal. A manufacturing mistake causing a tight clearance is an extremely rare occurrence these days. But, if there is something wrong with the engine clearances from the factory, no amount of gentle running will fix the problem.
    The real reason ???
    So why do all the owner's manuals say to take it easy for the first
    thousand miles ???
    This is a good question ...
    Q: What is the most common cause of engine problems ???
    A: Failure to:
    Warm the engine up completely before running it hard !!!
    Q: What is the second most common cause of engine problems ???
    A: An easy break in !!!
    Because, when the rings don't seal well, the blow-by gasses contaminate the oil with acids and other harmful combustion by-products !!
    Ironically, an "easy break in" is not at all what it seems. By trying to "protect" the engine, the exact opposite happens, as leaky rings continue to contaminate your engine oil for the rest of the life of your engine !!
    What about running it in the garage ???
    Maybe you have a new snowmobile and it's not quite winter yet, or a new bike and it's snowing...
    The temptation to fire up a new vehicle in the garage just to "hear"
    the new engine run can be very strong.
    This is the worst thing for a new engine, in fact, my advice is:
    don't even start it up until you're ready to warm it up for the first ride.
    The reason is that brand-new rings don't seat all the way around the 360 degrees of their circumference. The gas pressure from hard acceleration forces the rings to contact the cylinder around their entire circumference, which is the only way the rings can properly wear into the exact shape of the cylinder to seal the combustion pressure.
    Now, imagine if the engine is run in the garage. There is no load on the engine, so the rings are just going up and down "along for the ride". Only a small portion of their surface is actually contacting the cylinder wall. The ring area that does contact the cylinder wears down the roughness of the honing pattern on the cylinder walls. Once the roughness of the cylinder is gone, the rings stop wearing into the cylinder. If this happens before the entire ring has worn into the cylinder and sealed, you will have a slow engine no matter how hard it gets ridden after that point.
    The difference between what happens in an engine running in the garage, versus one being ridden is a hard concept to put into written words, so if I may use the sounds that we all can relate to: it's the difference between "zing-zing-zing" and "bwaaaaaaaaaAAAAAA"
    During "zing-zing-zing" the rings don't get loaded for more than a split second, whereas during "bwaaaaaAAAAAA", the engine is in 100% ring sealing mode.
    Recent Snowmobile Info:
    Yamaha's break-in recommendation for the RX1 has been to idle the engine for 15 minutes.
    Some owners found that the heat build up from doing this was so extreme,
    that their taillight had begun melting (!!!)
    Yamaha has since changed the recommendation to three 5 minute idle periods.
    Why would Yamaha recommend a break in method which will prevent the rings
    from sealing as well as possible ??
    A Picture's Worth A Thousand Words:
    The piston on the right was broken in as
    per MotoMan's instructions.
    After a full season of hard racing:
    - Perfect Ring Seal ...
    - No Scuffing ...
    - Lots of Trophies !!!
    These Honda F3 pistons show
    the difference.
    Although these pistons came out of engines which were raced for a full season, they weren't set-up with any special clearances or other preparation.
    These engines were never worked on prior to being raced. They were totally stock as built by Honda.
    The only difference was the break in method they used...
    The one on the right was broken in as per MotoMan's instructions.
    The one on the left was broken in exactly according to the owner's manual. The resulting leaky rings have allowed pressure to "blow by" down into the crankcase on acceleration, and oil to "suck-up" into the combustion chamber on deceleration.
    Needless to say, this bike was slow !!
    It's up to you:
    The loss in power from an easy break-in and the resulting poor ring seal can be
    anywhere from 2% - 10% !!
    In other words:
    The gain in power from using this break-in method can be anywhere from 2% - 10% !!
    Update -
    Some have felt that the piston which was broken in hard in the above photo is too clean to be true !!
    "That piston is impossible, there must be some trick going on."
    So, here I present: "The Impossible Piston Museum"
    Here are 14 pistons from 14 different bikes, with several manufacturers represented. Some are from streetbikes and some from racebikes.
    All of the engines had the correct jetting, the reason some have black carbon deposits is because they were run on "pump gas", which burns dark regardless of the jetting. Whereas the lighter ones were run on oxygenated race fuel, which gives a very light tan to gray color. (Many of the black-carboned pistons were from racebikes.)
    Disclaimer:
    Absolutely no photo altering or physical cleaning of the pistons is allowed in the museum !!
    We run a legit exhibit, and all the artifacts on display are 100% genuine.
    Note:
    The controversial piston in the above picture is the last one in the middle row,
    and it's indicated by the arrows.
    You can take a closer look by clicking on the photos to see the full sized versions:
    It looks like there are more than 14 pistons, because the area in the 3 photos overlap.
    It's 3 segments of a panorama photo to give you multiple views of this extraordinarily rare collection.
    The pistons have been stacked for display purposes only, they aren't going back into engines. Always be super careful when handling pistons, as the aluminum is soft and very easily dented, causing combustion leakage, and friction ... neither of which is good for power.
    As in any museum, some of the specimens are better examples than others, but the point is that none have any leakage past the top ring, because they were all broken in by the method described here !
    The only impossible thing about these pistons ... is that it's impossible to achieve this result with an easy break-in.
    What about street bikes ???
    This piston is from a 650 Honda Hawk. The brown discoloration that extends up into the piston pin bore is burnt oil from the extreme heat leaking past all 3 rings !!
    The uneven heat leakage was so bad, that it caused the cylinder to distort and become out of round, causing piston to cylinder scuffing in the tight part of the "oval" cylinder.
    When I showed the customer his
    pistons, he said:
    " I don't understand how that happened, I followed the owner's manual break-in instructions 100% !! "
    Why would Honda recommend a break in method which will prevent the
    rings from sealing as well as possible ??
    Q: What's the third most common cause of engine problems ???
    A: Not changing the oil soon enough after the engine is first run !!
    Change Your Oil Right Away !!
    The best thing you can do for your engine is to change your oil and filter after the first 20 miles. Most of the wearing in process happens immediately, creating a lot of metal in the oil. Plus, the amount of leftover machining chips and other crud left behind in the manufacturing process is simply amazing !! You want to flush that stuff out before it gets recycled and embedded in the transmission gears, and oil pump etc...
    Why do the manufacturers recommend waiting until 600 miles to
    flush out all the loose metal ???
    3 more words on break- in:
    NO SYNTHETIC OIL !!
    Use Valvoline, Halvoline, or similar 10 w 40 Petroleum Car Oil for at least
    2 full days of hard racing or 1,500 miles of street riding / driving.
    After that use your favorite brand of oil.
    Viewer Questions:
    Q: If break- in happens so quickly, why do you recommend using petroleum break- in oil for 1500 miles ??
    A: Because while about 80% of the ring sealing takes place in the first hour of running the engine,
    the last 20% of the process takes a longer time. Street riding isn't a controlled environment, so most of the mileage may
    not be in "ring loading mode". Synthetic oil is so slippery that it actually "arrests" the break in process before the rings can seal completely. I've had a few customers who switched to synthetic oil too soon, and the rings never sealed properly no matter how hard they rode. Taking a new engine apart to re - ring it is the last thing anyone wants to do, so I recommend a lot
    of mileage before switching to synthetic. It's really a "better safe than sorry" situation.
    Q: My bike comes with synthetic oil from the factory, what should I do ??
    A: I recommend changing the factory installed synthetic oil back to petroleum for the break-in period.
    Q: What about the main and rod bearings, don't they break - in ??
    A: Actually, the operation of plain bearings doesn't involve metal to metal contact !! The shiny spots on used
    bearings are caused from their contact with the crankshaft journals during start up after the engine has been sitting a while,
    and the excess oil has drained off. This is the main reason for not revving up the engine when it's first started.
    The subject of plain bearings is one of the most mysterious aspects of engines, and will be covered in a future issue
    of Power News. In it, I'll reveal more information that fully explains the non-contact phenomenon.
    Q: Why change the oil at 20 miles ?? Doesn't the oil pick up
    screen catch the aluminum bits ???
    A: It's true that the screen stops the big pieces, but many areas of the engine aren't within the oil filtration system. The oil that is splashed around will circulate metal debris to the lubricated bearing surfaces. For example, transmission gears and their ball bearings are unprotected by the filtration system, and even the cam chain makes a perfect "conveyer belt" to
    bring metal debris up into the cylinder head !!
    A close examination of a new engine will reveal lots of aluminum deposits on steel parts. This aluminum coats and tightens
    up the clearances of the parts, which creates a loss of power. Most of the time I spend "blueprinting"
    an engine is actually inspecting every part and "de-aluminizing" them !!
    I prefer to remove the oil pan and clean the aluminum bits out of a new engine out that way, but a $20 oil change
    is an easy and inexpensive way to flush the initial particles that come loose in the first miles.
    Q: What about motorcycle V.S. car oils ???
    A: This is a topic all by itself !! It will be covered in a future issue of Power News.
    Q: Will this break - in method cause my engine to wear out faster ???
    A: No, in fact, a poor ring seal will allow an increase in the by products of combustion to contaminate the oil.
    Acid contamination and oil consumption are the 2 reliability problems which are the result of an
    "owner's manual" or "magazine tech article" style easy break-in.
    By following the instructions on this page, you'll find that your oil is cleaner and the engine will rev quicker.
    Plus, you'll have much better torque and power across the power range from the vastly improved ring seal.
    Reliability and Power are 100% connected !!
    ahahahhahahhahahahahhahahaha
    qui siamo ai virtuosismi della masturbazione mentale...
      tutto il tempo che PERDI a farti le seghe (mentali ) e a cercare su internet ste minkyate lo sottrai a FINIRE sto beneamato rodaggio gabel
      bastaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa buttati sulla a4 e finiscilo non ne possiamo + del tuo rodaggio!!!!!!!!!
        :quot:
          occhio che se lo fai male perderai almeno 2 cv dopo i 20000km
            Voi mi volete maleeeeeeeeeeeeeeeeeeeee
            Daiiii, come la vedete 'sta storia dell'olio minerale semisintetico?!?
              Vale ma mi spieghi che problemi hai con le moto?
                vabb? chieder? consigli ad uno che almeno di gomme ci capisce...Diaavel. :gaen:
                  ecco bravo!
                  scherzi a parte io ti giuro che queste paranoie non riesco a capirle...
                  una moto nuova va presa, fatto il rodaggio come libretto (+ o -) e dato gas, stop, tanto non ci farai 90000km, non ci devi correre il mondiale stock e in ogni caso non si rompe causa rodaggio fatto male...
                  tutto quello che vuoi fare di diverso che vantaggi pensi ti dia?
                    ecco bravo!
                    Boh, pi? durata, migliore usura, quindi minori consumi...perch? no, se ci scappa un cavallino in pi? mica mi spiace...
                    Tu dici <<non ci farai 90milakm>>...per? intanto i 40mila con lo Zx12r li ho belli che passati...
                    Io ho venduto le altre moto SOLO PERCHE' ci sono stati validi motivi...se non mi si fosse graffiato il telaio avrei ancora lo ZZR1400...se non l'avessi stesa avrei ancora la Tuono, se non l'avessi ...no beh, la B-King fu un po' un colpo di testa...e la Hayabusa l'ho venduta perch? mi hanno fatto un'offerta assurdamente conveniente...per dire che DI SOLITO compro per tenere per sempre non per vendere a breve...
                    e vorrei che fossero sempre sane e longeve...
                    e mo' mi incuriosiva 'sta cosa del semisintetico...tutto qui...
                      Guarda Gabel,
                      la faccenda dell'olio minerale la sapevo anche io, ed infatti, oltre al primo cambio d'olio effettuato a circa 150Km (olio praticamente diventato metallico), ho continuato a mettere un ottimo minerale (Bel Ray) fino ai 2000km. Solo dopo ho comiciato con il sintetico.
                      Per il rodaggio, avevo visto da tempo l'articolo di Motoman su Mototune USA. Puo' sembrare strano ma non ha tutti i torti. Piu' alta la PME e piu' forza fanno i segmenti sulle pareti. Non credo al rodaggio piano piano per motivi appunto di "glazing", nonche' al cattivo addattamento delle fasce alla superficie del cilindro; tuttavia non credo neanche sia intelligente tirare alla morte il motore sin dall'inizio.
                      Mi sono quindi tenuto a meta' delle due teorie e finora mi sto trovando molto bene, con un consumo d'olio davvero trascurabile.
                      Considera comunque che e' anche plausibile che i costruttori predichino prudenza nei primi periodi, non solo per i motori ma per far si che l'utente prenda conoscenza del mezzo. Un incidente con la moto non e' mai una buona pubblicita' per una casa costruttrice.
                        Originally posted by Mauri65 View Post
                        Guarda Gabel,
                        Quoto tutto.
                        Anche io credo che il rodaggio vada fatto "alla garibaldina" ed e' quello che ho fatto quando ho dovuto rodare motori nuovi, sempre con ottimi risultati. Certo, il motore va comunque "rispettato" ma il gas e' bene dargliene parecchio sin dai primi Km.
                        I rodaggi "paranoici", quelli della serie non superare tot giri per i primi tot Km. li ritengo dannosi per il motore. Servono soprattutto, come scritto sopra, per far prendere confidenza al nuovo proprietario con il mezzo e parare il didietro delle case.
                        Ciao
                        Ciao
                          Grazie Mauri65, Grazie rickrd ma appunto pi? che la MODALITA' , mi incuriosiva molto sapetre come la pensavate sul discorso dell'olio semisintetico/minerale...
                            Gabel... l'olio minerale offre maggior lubrificazione di un olio sintetico ma ha maggiori limiti in quanto a temperature d'esercizio e decadimento.
                            In rodaggio si pu? dunque preferire l'olio minerale, di buona qualit? sapendo che tanto che il motore non verr? sottoposto a cicli particolarmente stressanti.
                            Il rodaggio consiste nel "consumare" quel tanto che basta gli elementi di tenuta al fine di farli lavorare meglio... che in altri termini vuol dire che il motore da nuovo ha delle tenute leggermente peggiori di un motore con qualche km... in funzione di tutto ci? a motore nuovo ? consigliabile utilizzare oli con gradazione leggermente pi? viscosa.
                            Una volta finito il rodaggio si pu? sostituire l'olio con del nuovo sintetico e di giusta gradazione che garantisce ottima prestazione in condizioni di peggior stress del motore.
                              Per me il discorso olio synt/min ha un suo razionale anche se non credo sia fondamentale.
                              Ciao
