zx-10 originale VS zx-10 PSG-1
    PSG-1 Ninja ZX-10R
    Engine
    Liquid-cooled, 4-stroke In-Line Four
    Displacement
    998 cm
    Bore and stroke
    76 x 55 mm
    Injection
    ?43mm x 4 Kawasaki sub-throttles, 4 injectors
    Maximum power with RAM Air
    More than 137kW@13,500 rpm
    Frame
    Diamond Perimeter, pressed aluminium
    Front suspension: 42 mm inverted fork Ohlins FGR46 Rear suspension: Bottom-Link Uni-Trak with gas-charged TTX Ohlins shock
    Brakes
    Front Brakes: Dual semi-floating 320/310 mm floating Braking discs, Brembo Calipers
    Rear Brakes: Single 218 mm disc, single piston calipers
    Weight
    165 kg
    ECU
    Pectel SQ6M with data acquisition system
    Ninja ZX-10R
    Engine
    Displacement
    998 cc
    Bore and stroke
    76.0 x 55.0 mm
    Injection
    ?43 mm x 4
    Maximum Power
    128.7kW {175 PS} / 11,700 rpm
    Frame
    Backbone/Twin-tube, aluminium Rear shock: Bottom-Link Uni-Trak with gas-charged shock and top-out spring. Front fork: 43 mm inverted fork with top-out springs
    Brakes
    Front Brakes: Dual semi-floating 300 mm petal discs, dual radial-mount, opposed 4-piston, 4-pad Rear Brakes: Single 220 mm petal disc, single-bore pin-slide
    Weight
    175 kg
    Motorcycle & Engine Company is the sole division of Kawasaki Heavy Industries, Ltd. that provides products directly to general consumers. The company manufactures a broad range of products, including motorcycles, ATVs (all-terrain vehicles), recreation utility vehicles, utility vehicles, JET SKI® watercraft and general-purpose gasoline engines; and supplies them to markets around the world.
    pensavo che la differenza di peso fosse più di 10 kg!!
      ma non dichiarano quasi mai i dati reali...anche con i cv mi ricordo che (per esempio yamaha e honda) avevano dichiarato 210cv e oltre...quell'"e oltre" uno poi lo interpreta come gli pare..stesso per i kg
        ma infatti peso e potenza della PSG-1 nn mi convincono molto...
          diciamo invece che non sono molto concreti quelli del modello stradale
          cio?, NON pesa 175 kg effettivi e NON ha 175 cv effettivi..
          mentre la SBK pesa SICURAMENTE 165 kg (meno non credo, visto che mi sembra sia il minimo da regolamento) ed avr? CONCRETAMENTE 190 cv alla ruota o pi?..
            appunto!! d'accordo con te!
              secondo me qualcuno spera in una risposta un po' piu'... ehm...ufficiale
              in effetti la forchetta peso/potenza mi sembra troppo simile rispetto alla produzione in serie...
                10kg?!? allora ci sono vicino come peso...
                  Mah.. mah... mah....
                  Peso e potenza.. li vedo da ridere... poi cmq. bisogna vedere come cambia la geometria della moto, l'erogazione ecc. ecc.
                  Una superbike è mooooooooooooolto diversa dalla moto da cui deriva..
