SU RICHIESTA DEL CARISSIMO PONTEHRC
POSTO LE FOTO DEL LAVORETTO FATTO ALLA BAMBINA IN QST INVERNO DA CANI.
MAGARI A QUALCUNO INTERESSA...
PRIMA DI TUTTO BISOGNA FARSI FARE DA UN BUON TORNITORE UNA BOCCOLA CON FLANGIA DELLA MISURA GIUSTA( IL FORO NEL CARTER MOTORE DOVE ALLOGGIA IL PERNO FORCELLONE DELLA SP1 E' DI DIAMETRO PIU' LARGO DI QUELLO DELLA 2 ).
![](http://img184.imageshack.us/img184/5154/immagine001ny2.jpg)
SI SMONTA IL FORCELLONE ORIGINALE....(LOGICO)
![](http://img184.imageshack.us/img184/8643/immagine203uw4.jpg)
SMONTATO IL FORCELLONE SI INFILA LA BOCCOLA NEL FORO DEL TELAIO DALLA PARTE DEL PIGNONE.(IL DIAMETRO DELLA FLANGIA PASSA PERFETTAMENTE DAL FORO).AIUTANDOCI CON UN MARTELLO DI GOMMA E UN PEZZO DI LEGNO X NN ROVINARE LA FLANGIA IN ALLUMINIO..
PS..VISTO CHE E' PRECISA AL DECIMO,MEGLIO INGRASSARLA UN PO' O METTERE UN PO' DI SVITOL X AGEVOLARNE L'INGRESSO.
![](http://img184.imageshack.us/img184/8205/immagine002oh7.jpg)
![](http://img60.imageshack.us/img60/6541/immagine003js3.jpg)
![](http://img60.imageshack.us/img60/171/immagine004ul3.jpg)
FATTO QUESTO SI PUO' MONTARE IL BELLISSIMO FORCELLONE DELLA SP2!!!!!!
ECCO IL LAVORO FINITO...E VISTO CHE C'ERO HO MONTATO UN BEL WP!!!
![razz](https://www.daidegasforum.com/core/images/smilies/icon_razz.gif)
![Wink](https://www.daidegasforum.com/core/images/smilies/emoticon-wink.gif)
![briggin](https://www.daidegasforum.com/core/images/smilies/icon_biggrin.gif)
![grin sevil](https://www.daidegasforum.com/core/images/smilies/grinsevil.gif)
![](http://img258.imageshack.us/img258/4481/immagine005dp1.jpg)
