Chi la conosce ? avete avuto esperienze o sentito commenti ??
The BX 449 offers aggresive styling with exceptional performance and agility, all part of Benelli's entry into the off-road market
EUROPE SPECIFICATIONS: 2008 Benelli BX449 Cross
UK MSRP ?5499 RRP + OTR
ENGINE
TYPE Single cylinder, 4 stroke, liquid cooled, 4 titanium valves, double overhead camshaft, with balancer shaft
DISPLACEMENT 449 cc
BORE x STROKE 98 x 59,5 mm
COMPRESSION RATIO 12,5:1
RATED OUTPUT 41,3 kW (56 CV) @ 9500 rpm
MAX. TORQUE 45 Nm (4,6 kgm) @ 7000 rpm
FUEL SUPPLY Carburetor - Keihin FCR MX 41
EXHAUST SYSTEM n.d
CERTIFICATION n.d
CLUTCH Wet clutch
GEARBOX 5 speed
FINAL DRIVE Chain drive, ratio 14:51
CHASSIS
FRAME Single tube cradle with forged, casted and extruded elements and
carbon structural part patented.
Light alloy rear subframe
FRONT SUSPENSION ?50 mm upside-down fork, with hydraulic extension and compression adjustments
FRONT SUSPENSION STROKE 307,5 mm
REAR SUSPENSION Aluminum casted swingarm, progressive rear dumper completely adjustable in extension, compression and spring preload
REAR SUSPENSION STROKE 315 mm
FRONT BRAKE Single floating disk ?260 mm with 2 pistons floating caliper
REAR BRAKE Single disk ?220 mm with single piston floating caliper
FRONT RIM 1,6?x21?
REAR RIM 2,15?x19?
FRONT TYRE 80/100 R21
REAR TYRE 110/90 R19
SIZES
LENGHT 2160 mm
WIDHT EXCLUDING MIRRORS 810 mm
HEIGHT EXCLUDING MIRRORS 1240 mm
SEAT HEIGHT 960 mm
WHEELBASE 1470 mm
UNLADEN WEIGHT* 108 kg
ROAD READY WEIGHT** -- kg
PERMITTED TOTAL WEIGHT -- kg
USABLE TANK VOLUME 8,5 lt
RESERVE n.d
ENGINE
DISPLACEMENT 449 cc
EXHAUST SYSTEM n.d
CERTIFICATION n.d
CLUTCH Wet clutch
GEARBOX 5 speed
CHASSIS
FRONT RIM 1,6?x21?
REAR RIM 2,15?x19?
SIZES
LENGHT 2160 mm
SEAT HEIGHT 960 mm
WHEELBASE 1470 mm
RESERVE n.d
