MOTION SBK Ducati M9
    Che ne dite? Han speso due soldi no?
    SUSPENSION:
    Ohlins Black anodized R&T FG331 Forks with billet radial bottoms
    Ohlins Black anodized Rear Shock DU301 with Red Spring and hydraulic preload
    Ohlins Steering Damper with SBK piston Kit
    Billet upper and lower triple clamps
    CHASSIS:
    2004 999 SBK Frame with adjustable eccentric
    Magnesium Single Sided Swingarm, MV Style with Magnesium eccentric and Ti hardware
    Marchesini Magnesium 10 spoke wheels (Dunlop Tires)
    Black Aluminum Subframe
    Magnesium Headlight Bucket and Support Arms
    Billet Rearsets, race pattern
    BRAKING:
    Brembo FO7 320mm Narrowband SBK Rotors with Titanium Rotor Bolts
    Brembo Radial Calipers with Titanium Caliper Bolts, Billet spacers
    FO7 Brake Line with Aluminum banjos and bleeders
    Brembo Radial Brake Master 19 x 20 with micro switch
    Brembo Radial Clutch Master 16 x 18
    ENGINE:
    2006 MOTIONSBK engine - M9
    High Comp Pistons with Ti wrist pins
    Balanced & Blueprinted
    Magnesium Clutch Case with Ti bolts
    FO7 Billet adjustable H2O Cylinder Outlet
    RS Slipper Clutch
    Afam Quick Change Carrier
    Afam 38t rear sprocket
    Afam 14t lightened front sprocket
    DID ERV3 520 SBK Chain
    FO7 Factory Quick Shifter with Bypass and Carbon switch bracket
    Billet Crankcase Breather
    57 into 60mm Termignoni Full exhaust w/Titanium Can, ECU and Filters
    BODY:
    Custom MOTIONSBK paint scheme, 1 off, not to be duplicated, numbered signed and badged #002
    Carbon MOTION Nose Fairing with Titanium mesh
    Carbon MOTION 1pc FO7 Tail Fairing with Titanium mesh
    Carbon 1pc Side Fairings
    Carbon Deflectors
    Carbon V-pc
    Carbon Inlet Covers
    Carbon Tank/Key shroud
    Carbon Tank Bump Guard
    Carbon FO7 Front Fender
    Carbon Exhaust heat shield
    Carbon Swingarm heel protector
    Carbon FO7 Clutch Cover
    Intergrated turn signal/tail light with license plate relocate
    FO7 Factory Windscreen
    Billet Quick Release Fuel Cap
    Suede Seat and Bump Pad
    Volendo la vendono sulla baia...
    http://cgi.ebay.com/ebaymotors/Motorcycles___MOTION-DUCATI-002-M9_W0QQitemZ290288483325QQddnZMotorcyclesQQddiZ228 3QQcmdZViewItemQQptZUS_motorcycles?hash=item290288 483325&_trksid=p4506.c0.m245&_trkparms=65%3A3|39%3 A1|240%3A1308
    STUPENDA!!
      Bellissima
        Le pinze non mi piacciono molto fatte così.. boh..
          molto carino il copri faretti, meno l'aver messo ancora i deflettori laterali.
            Che ? il coprifaretti?!?!?
              niente niente male
                A mio modestissimo parere però si son persi sullo scarico e sul piedino forcella..
                  Realizzazione da sogno.
                    bellissima realizzazione!!!
                      quel toc ad plastica sopra i faretti, luci o come vuoi chiamarli
                        molto ma molto bella
                          A mio modestissimo parere per? si son persi sullo scarico e sul piedino forcella..
                          effettivamente
                            Ma le SBK, cos? come le RS, non avevano il traversino?
                              me lo sono chiesto anch' io
