questa e' la mia ducati preferita
    Ducati TT2
    Engine
    Type: 4 stroke 90 degree longitudial V-twin
    Total displacement: 650cc
    Bore: 82mm.
    Stroke: 61.5mm
    Compresion ratio: 10:1
    Carburators: 2 Dellorto 36mm
    Timing system: desmodromic S.O.H.C. driven by toothed belt.
    Ignition: Bosch electronic BTZ type.
    Electric starter.
    Transmission
    Type: Primary by gears, final by chain.
    Gearbox: 5 speed.
    Clutch: oil bath multidisk.
    Wheels Type: E P M cast alloy
    front: 3.00/16
    rear: 3.00/18
    Brakes
    Front: Brembo Gold Line 280mm double disk
    Rear: Brembo Gold Line 260mm single disk
    Tyres Front: 120/80 V 16
    Rear: 130/80 V 18
    Frame
    Type: overhead tubular ladder, chrome moly tubing.
    Front: Marzocchi ZTi 35mm adjustable damping front fork.
    Rear: swing arm fulcred on engine, Marzocchi PVS-1 adjustable monoshock.
    Dimensions
    Length: 2000mm
    Width: 650mm
    Wheelbase: 1360mm
    Seat height: 762mm
    Dry weight: 136 kg
    Fuel capacity: 18,2 lt
    Performance
    Max speed: 225 km/h
    mamma mia che fatica pe' trova' i dati tecnici
      Originally posted by kaciaro
      Ducati TT2
      Engine
      Bore: 82mm.
      Stroke: 61.5mm
      Electric starter.
      Transmission
      Gearbox: 5 speed.
      front: 3.00/16
      rear: 3.00/18
      Brakes
      Rear: 130/80 V 18
      Frame
      Dimensions
      Length: 2000mm
      Width: 650mm
      Wheelbase: 1360mm
      Seat height: 762mm
      Dry weight: 136 kg
      Performance
      Max speed: 225 km/h
      Pure in inglese..
        136 KG BUONO NO^^????
