centralina nemesis per comandare dtc 1098r/1198s
    molto interessante: attiva e disattiva il dtc senza passare dal menu del dashboard anche con moto in movimento. in pi? regola la raccolta dati dei sensori in base ai cerchi e gomme usate.
    se funziona ? uno spettacolo.
    qualcuno lo ha gi? provato???
    articolo in inglese:
    Nemesis Ducati 1098R TC-Pod DTC Controller
    Nemesis TC-Pod DTC (Ducati Traction Control) controller for Ducati 1098R. Can be used with both the stock ECU, Ducati Performance or aftermarket ECU that supports DTC. This is a plug and play kit!
    What is included in this kit:
    + TC-Pod
    + Mount bracket for center position
    + Remote switch assembly
    + Spacer + screws
    + Wiring loom for 1098R
    Features of the TC-Pod for Ducati 1098R:
    +DTC, ON/OFF and UP/Down Level, at the touch of a button and no need to stop the bike
    +No need to activate the DTC system via the dashboard setup pages, all can be done via the TC-Pod.
    +Speed correction setup, to trim the DTC system for different tire or wheel diameters.
    +100% compatible with the standard Ducati ECU with 'Plug n play' kits for 1098R / 1198S / Streetfighter-S.
    +Multi LED display to indicate the amount of DTC correction being applied in real time.
    +Numeric display of the current DTC level.
    +Adjustable back lit displays for day or night riding.
    +Memory of speed correction and TC level settings, even after power off.
    +Warning LED in case of DTC or sensor errors, and built in self-diagnostic capability.
    +Supplied with brackets to fit the handlebars, or alternative center mounting with remote buttons.
    +100% compatible with all other CAN based bike systems such as DDA, DTC, ECU & dashboard.
    Base PN: TC-POD-1098R
    Manufactured by: Nemesis
    pi? precisamente....
    http://www.magneti-marelli.com/TC-Pod.html
      proprio quella
