S1000RR Superleggera Killer 216 CV alla ruota
    By Alpha Racing
    FIM World Superstock Build
    2013 BMW S1000 (HP4) 2013- BMW HP4 RR Chassis & Swingarm 1
    WHEELS
    3631A080A01-01 Forged Magnesium PVM Racing R Wheel Set for BMW HP4 1
    3631HP28A00-01 alpha Racing Rear Wheel Spacers, S1000RR/HP4 1
    87128 SC-Pirelli Pirelli Super Corsa Tires 1
    3631A060A00-01 alpha Racing Torque Cushion for PVM Wheels 5
    3631A002A00-01 alpha Racing 90? Angled Tubeless Valve for OEM Wheel (11.3mm) 2
    BRAKES
    3421A100A00-01 alpha Racing Rear Brake Disc 220 x 4mm for BMW HP4 for PVM Racing Wheel 1
    3411A100B06-RL alpha Racing Front Brake Disc 320 x 5.5mm EVO Left/Right, for PVM 2
    3271A013A00-01 Brembo Radial Master Cylinder 19RCS for BMW S1000 - HP4 1
    3432A001A01-01 alpha Racing Rear Brake Line (630 mm) 1
    3411A120C00-01 alpha Racing Brake Pad Set, Front Duo Carbon HP4 1
    3432A010A00-01 alpha Racing Stainless Steel Front Brake Line 3-pc. Set 1
    3411A005P00-01 Brembo HP4 Calipers 1
    3311A996A00-01 Brake fluid Brembo LCF 600 1
    CONTROLS
    3271A004B01-01 alpha Racing Fast Throttle Kit 63? with Medium Grips for BMW S1000 RR - HP4 1
    3272A021A00-01 alpha Racing WSBK Clutch Lever Assembly 1
    3272A002A00-01 alpha Racing Brake Lever, Long for Brembo 19RCS for BMW S1000RR - HP4 1
    3272A003A00-01 alpha Racing Remote Brake Lever Adjuster 1
    3271A212B00-01 alpha Racing Fast Mount Clip-On Set, 7? Angle for HP4 (55mm Forks) 1
    PN Alpha Racing Sock Cover ? Embroidered. 1
    PN Alpha Racing Brake Reservoir Aluminum Cover 1
    3271A001B40-01 alpha Racing Aluminum Steering Stop Kit for S1000 RR - HP4 1
    3143A015B00-01 alpha Racing Complete Kit (Plug & Play) Ignition Delete for BMW S1000 RR & HP4 1
    4671A001A01-01 alpha Racing Rear Sets for BMW S1000 RR & HP4 1
    6131A090C00-01 alpha Racing BMW HP4 Race Switches Kit "Plug & Play" 1
    CARBON BODYWORK
    4663A201C01-01F alpha Racing Complete Racebody Kit, from WSBK/WSSK in Carbon 1
    aP-CP-9999-SP Custom Paintwork by alpha ? Wheel Color to Match (SL Ducati PPG) 1
    4663A090A02-01 Racing Windscreen Long for Race Fairing Kit, Clear, with color matched decal. 1
    4663A201A20-01 alpha Racing Quick Fairing Mounting Kit, 7 pcs. 1
    ACCESSORIES
    4663A300A10-01 alpha Racing Carbon Fiber (Shark Fin) Chain Protector
    17117687715-01 alpha Racing Radiator Cap 1.8 Bar for BMW S1000 RR & HP4 1
    1712A001A00-01 alpha Racing Coolant Hose Kit for BMW S1000 RR & HP4 1
    DID-520-ERV D.I.D 520 ERV3 RACING CHAIN 1
    PN- alpha REAR SPROCKET - Teeth: 1
    PN- alpha FRONT SPROCKET - Teeth: 1
    8123A010B02-01 alpha Racing Rear Spool Set for Rear Stand, Black for BMW S1000 & HP4 1
    Electronics
    aPXX1A001A00-01 alpha Racing Bump & Blip CLUTCHLESS DOWNSHIFTING System 1
    3451A010A00-01 alpha Racing DTC Race Controller Kit Box for BMW S1000 - HP4
    13618523966-01KIT Complete Kit HP Race ECU, Unlock, Calibration Kit 2, Unlock for S1000 RR & HP4
    12527727856 BMW S1000RR Slick Mode Enabling Plug 1
    6113A001A00-01 alpha Racing Racing Plug Set, 5-piece for BMW S1000 RR - HP4 1
    6121A000A00-01 alpha Racing Lithium Polymer Racing Battery 1
    Power Upgrades
    ST1EN100‐RE1 WSSK RACE MOTOR, (215-218 RWHP), Stage 3 head, Stage 1 cams, V1 Springs. 1
    1172A001A00-01 alpha Racing SAS System Valvecover Block-off Plates for BMW S1000 RR & HP4
    1173A001A00-01 alpha Racing SAS Airbox Cover Plate for BMW S1000RR & HP4 1
    AR100111A2DTC alphaRacing's HP Race Kit ECU Mapping (pre-installed for DTC/DDC/QS) 1
    AKRA-100-HP4-L AKRA Competition Exhaust Full System - HP4 1
    MC-110Race Racing Air Filter Plate System for HP4 ? with Adjustable Angle 1
    aP-98172398 Rear rotor, rear brake line and pads, WSBK rear caliper P4, with alpha bracket. 1
    PN alphaRacing RACE Air funnel kit (4) pcs. V3.
    $58,880 (USD)
    HP4 "Superleggera Killer" (Limited Edition) Project by alpha – alpha Performance
    Sti caxxi...
      Alpharacing te la fa come vuoi, volendo ti pu? fare pure la Sbk di Reiterberger
        B? per 58 mila dollari questa.. ok esclusa la forcella Ohlins pressurizzata.. ma manco tantissimo! (avendoli )
          A pensare che ci sono persone che se la possono permettere...
            Un missiletto
              By Alpha Racing
              WHEELS
              BRAKES
              CONTROLS
              CARBON BODYWORK
              ACCESSORIES
              Electronics
              Power Upgrades
              $58,880 (USD)
              Ecceziunaleee , pure di prezzo
                Calcolando cosa costano certe moto (D16RR, superleggera) direi che questa le ammazza tutte a molta meno spesa.
                Certo, 216 cavalli alla ruota, ? un motore da 800-1000 km al colpo, e revisionarlo, non ? come tagliandare la moto originale.
                  Che mezzo!
                    MINGHIAAAAAA.........:1:
                      Re
                      Con 216 civ alla ruota il BMW fa circa 4000 km di pista tirati
