la HPN ? un'azienda di seibersdorf che 'elabora' le bmw partendo, per lo pi?, dalla meccanica GS
sono interventi 'importanti' come si pu? vedere, ad esempio, dalla scheda tecnica della prima moto (HPN Rallyesport)
Dimensions, weights: Wheelbase: 1640 mm Unladen weight without fuel: ca 195 kg Unladen weight DIN with fuel: ca. 200 - 240 kg, depending on accessoires and tank size Engine, electrical system, gearbox: Displacement: 1043 ccm Power output: ca. 51 KW / 72 PS Max. speed: ca. 180 km/h Oilcooler: BMW with HPN-thermostat Oilpan: Conical spacer with bottom plate in dural Airfilter: BMW original or HPN racing Tank: Main tank 19l steel or 42 l, additional tank 7 l Exhaust system: HPN-Baja stainless steel muffler with CFK-covers or racing Generator: BMW serie Ignition: BMW Serie or Q-Tech double-ignition Battery: 12 V, 20 Ah oder 12 V, 8 Ah Instrumentation: BMW serie GS or elektronical speedometer, different manufacturers Gearbox: BMW 5-speed, optional 1.st gear shorter and 5.th gear longer Frame and brakes: Mainframe: BMW GS duplex steel tube cradle with HPN reinforcements Subframe: BMW with HPN reinforcments Teleskopic front fork: Marzocchi Magnum, ?50mm, 285 mm travel, or WP Suspension Upside-Down 295 mm travel Shock absorber: Special built WP Suspension with adjustable compression and rebound damper settings and hydraulic adjustable spring preload Swing arm: BMW R1100GS serie or welded aluminum construction, 245 mmtravel Final drive: BMW original, ratio 3.09 or 3.20 Front brake: Single- or double disk, depending on fork Rear brake: Drum- or disk brake Wheels: BMW GS serie orHPN Sport with rim for tube tyres Front tire: 90/90-21?? different manufacturers Rear tire: 140/80-17?? or 18?? different manufacturers Other equipment: Head light: 180 mm H4 BMW serie
Cylinder protection guard: BMW GS serie or HPN racing Center stand: BMW GS with HPN modifications Footrests: BMW GS
