Alberto ma avevi dato una occhiata sul sito "dea-engineering.com/?p=18" ??
DEA Single cylinder superkart engine orders are open.
Price is 3900,00? (+ VAT) and includes these parts:
? head cover
? cylinder head
? cylinder
? piston
? crankshaft
? balance shaft
? crankcase
? clutch cover
? water pump
? bearings
? oil seals
? exhaust manifold
The order is valid when you have returned the following order form at our email dea@dea-engineering.com and you have paid the advance (which is 500,00?).
The first batch will be consigned in January after the regular inspection, and we?ll follow the order placement date.
The engines will be sold by DEA Technology Ltd. (UK).
Main parts included in the price (engine packet)
- head cover
? cylinder head
? cylinder
? piston
? crankshaft
? balance shaft
? crankcase
? clutch cover
? water pump
? bearings
? oil seals
? exhaust manifold
Honda CR 250 parts that you can use
Gearbox and clutch: you can use the one taken from Honda CR 250
Rotor and stator: you can use the one taken from Honda CR250
To keep the price low, we didn?t put in our ?engine packet? the CDI, this because many still have it and still uses it on their Honda. Same thing for intake manifold, carburettor and airbox.
Same thing for the exaust, because usually the preparetors prefers to mount their own.
Parts that are not in the ?engine packet? that we will make too
In a second phase we will make some other parts, too.
You can decide to continue to use the Honda/whatever or get ours, you are free to choose what you prefer. These parts are:
? DEA exhaust
? DEA silencer
? DEA CDI
? DEA intake manifold
? DEA carburettor
? DEA airbox
? head cover
? cylinder head
? cylinder
? piston
? crankshaft
? balance shaft
? crankcase
? clutch cover
? water pump
? bearings
? oil seals
? exhaust manifold
- head cover
? cylinder head
? cylinder
? piston
? crankshaft
? balance shaft
? crankcase
? clutch cover
? water pump
? bearings
? oil seals
? exhaust manifold
? DEA exhaust
? DEA silencer
? DEA CDI
? DEA carburettor
? DEA airbox
